Replacing ignition barrel
To be sure remove the negative from the battery. After that remove the plastics around the barrel so you can see the whole barrel. At the left side you will see 2 bolts holding it. Get them out. After that remove the plug at the back. Get the new one and fit it on the same place. There is only one way it will fit so dont worry. Put the plug in. Put on the negative and try it out. ;)
  • 2 months later...
