Coxxy_94GT Posted December 7, 2013 Posted December 7, 2013 Has anyone fitted a wms break kit with 15x7 rota slip steams .. If so what kit did you get and is it worth the money? Quote
Keri-WMS Posted December 7, 2013 Posted December 7, 2013 The 275x22 4P107 and 277x25 4P109 kits both fit the ET40 15x7 Rota Slipstream from what I've been told. The 4P109 was tested using PDF/card templates, the 4P107 was tested in real life by someone fitting it.... Quote
The_Notorious_C_A_T Posted December 8, 2013 Posted December 8, 2013 Did you ever make a 266mm set up in the end Kerry? Quote
Keri-WMS Posted December 8, 2013 Posted December 8, 2013 Did you ever make a 266mm set up in the end Kerry? Sort of - it ended up being a 260x25 and the prototype is sitting on my desk in front of me! I just need to run off a few proper brackets so I can ship some... Quote
The_Notorious_C_A_T Posted December 8, 2013 Posted December 8, 2013 Keep me updated on them will you bud. :-) Quote
Coxxy_94GT Posted December 8, 2013 Author Posted December 8, 2013 Cheers liam , what hub size would i need for a 1995 starlet gt ? Quote
Coxxy_94GT Posted December 8, 2013 Author Posted December 8, 2013 And liam is that the 275x22 or 277x25? Quote
Liam_D Posted December 9, 2013 Posted December 9, 2013 Cannot remember for sure dude if I remember correctly it's the bigger of the two. Quote
Keri-WMS Posted December 9, 2013 Posted December 9, 2013 Cheers liam , what hub size would i need for a 1995 starlet gt ? Do you mean 55mm or 54mm bores for the discs? It's 54mm up to '92, '92-on is 55mm. And liam is that the 275x22 or 277x25? I've got Liam as having the 275x22 4P107 in my records... Quote
Coxxy_94GT Posted December 10, 2013 Author Posted December 10, 2013 Ah sweet ill pm you sometime after christmas about getting a set Quote
smithyithy Posted January 1, 2014 Posted January 1, 2014 What's the biggest size you can get under 15's?I'm gonna be running 16's daily so I've got a fair bit of room, but I'll probably use a set of 15's with 888's as track / sprint tyres so will need to get them over the disks too.. Quote
loz180691 Posted January 1, 2014 Posted January 1, 2014 I got these a few months back after they bedded In a hundred or so miles they are awesome Quote
