andyllewellyn Posted December 12, 2013 Posted December 12, 2013 As title, have a decent sr and want some more power, the revs pretty much drop off at 5800, can i fit the glanza cam springs and get it revving to 7800 or more, it is pretty much the same engine so in theory should be possible, other option is drive this engine into the ground and replace with a 4age, 1.8 vvti(140-190-g6-6speed) or supercharging but might be a hand full without power steering.Has anyone tried charging these, the power steering can't be that much of an issue can it?, i have seen polo's with 200hp plus(mk3g40) without power steering, even my old golf gti mk2 had no ps, so to charge or rev, pls helpAndy Quote
TurboTobz Posted December 12, 2013 Posted December 12, 2013 Google ecu crystal mod, real easy and has been done on 4efe ecus there shoukd be some info on old threads on here tggt and the aussie forum Quote
AdamB Posted December 12, 2013 Posted December 12, 2013 Change valve springs to something stiffer like the zisco ones and fit ARP rod bolts. One thing I always found with the N/A was it was lacking revs. Quote
