dan-the-man Posted December 14, 2013 Share Posted December 14, 2013 Noticed that the water temp has been taking a while to get to normal temp and the bottom rad hose is cold, so changed thermostat today and it's still the same, went for a 20 minute drive and it came up to temp, left it idling for another 10 minutes and the temp went down to about 1\4, and didn't rise. Bottom rad hose still cold.I have no idea what it could be. Do these cars normally take a while to get up to temp and the stat to open? Quote Link to post Share on other sites
aidanep71 Posted December 14, 2013 Share Posted December 14, 2013 The fan on constant ?? Quote Link to post Share on other sites
dan-the-man Posted December 14, 2013 Author Share Posted December 14, 2013 The fan doesn't come on at all Quote Link to post Share on other sites
yaristurbo Posted December 14, 2013 Share Posted December 14, 2013 Put a thermostat in mine today warms up fast and temp stays great now it had a 65 degree on in causing the issue Quote Link to post Share on other sites
dan-the-man Posted December 14, 2013 Author Share Posted December 14, 2013 The one that was in before was 82 degrees not sure what this one is though Quote Link to post Share on other sites
yaristurbo Posted December 14, 2013 Share Posted December 14, 2013 Most of the shelf are 82 bud are the heaters hot and what's temp sensor wiring like? Quote Link to post Share on other sites
dan-the-man Posted December 14, 2013 Author Share Posted December 14, 2013 Heaters work fine, is the temp sensor wiring the one on the stat housing? If so it was all intact, but looked quite brittle Quote Link to post Share on other sites
yaristurbo Posted December 14, 2013 Share Posted December 14, 2013 Might be corroded they usually are its the on facing bulk head green plug???? Quote Link to post Share on other sites
dan-the-man Posted December 14, 2013 Author Share Posted December 14, 2013 Yeah, that's the one. It feels like it's probably corroded inside, didn't bend it too much because it felt like it would snap off Quote Link to post Share on other sites
yaristurbo Posted December 14, 2013 Share Posted December 14, 2013 Get one cut off a loom with length of wire and swap it just in case Quote Link to post Share on other sites
1991 starlet owner Posted December 20, 2013 Share Posted December 20, 2013 Might be corroded they usually are its the on facing bulk head green plug????So if this is not working properly would this cause the thermostat to stay open and not let the engine warm up properly??Tom. Quote Link to post Share on other sites
