Dusty Posted December 14, 2013 Posted December 14, 2013 As title was out a run in the car y-day parked her up (she is low on fuel but not completly empty) went to start it this morning and she wouldn't go was turning over fine just not starting, bump start and she went but tried again few hours later and doin the same again, anyone know what could be the cause of this problem? Any help appreciated Cheers Dusty Quote
Beastmode panda Posted December 15, 2013 Posted December 15, 2013 Check spark plugs/HT leads first of all. Quote
Stu Posted December 15, 2013 Posted December 15, 2013 Yeah spark check is first port of call, followed by checking the injectors are working and their is pressure at the rail. Might be a fuel pump crapping out - just had a couple through for customers with similar issues and its been the pump both times. Quote
Dusty Posted December 15, 2013 Author Posted December 15, 2013 Ok guys I'm ordering a fuel pump and ignition upgrade kit from TD ,seen a post of people who can refurb injectors takin it off the road in jan anyway to do a good bit of work on it will keep uz updated tho guys Cheers Dusty Quote
