Mattysr Posted December 15, 2013 Share Posted December 15, 2013 Hi as the title says i have a sr will the corolla g6r gearbox fit i know you have to swap the bell housings to make it fit is that all that has to be done ? Quote Link to post Share on other sites
The Toffinator Posted December 15, 2013 Share Posted December 15, 2013 AFAIK The G6 1.3 4EFE Corolla box is a direct fit, some people have slight gear cable problems but easy sorted if you use the cable off that car.The G6R Corolla 1.6 4AFE Is the same box bar the bellhousing, which you swap over. Cable problem is the same again just use the cables Quote Link to post Share on other sites
Mattysr Posted December 15, 2013 Author Share Posted December 15, 2013 Ok cheers i suppose you use the standard clutch assembly from the starlet Quote Link to post Share on other sites
The Toffinator Posted December 15, 2013 Share Posted December 15, 2013 Yes mate or upgrade to a glanza clutch and flywheel setup Quote Link to post Share on other sites
JDMfreak Posted December 15, 2013 Share Posted December 15, 2013 you going for the 6 speed or 5 speed Quote Link to post Share on other sites
Mattysr Posted December 15, 2013 Author Share Posted December 15, 2013 6 speed im looking to get and it will be better box when i turbo it next year Quote Link to post Share on other sites
JDMfreak Posted December 15, 2013 Share Posted December 15, 2013 6 speed should fit on fine but I will warn you the closeness of the box to the chassis leg on passenger side is very tight and will bang off it best bet is to put a solid mount on the front gearbox side this will keep the box from banging of the chassis leg Quote Link to post Share on other sites
Mattysr Posted December 15, 2013 Author Share Posted December 15, 2013 Ahh good to know if not ill wait until i turbo it and put a glanza box on it Quote Link to post Share on other sites
JDMfreak Posted December 15, 2013 Share Posted December 15, 2013 just a head up drove one and for the life of me couldn't figure out where the banging was from till I was fitting new mounts and seen the rubbing on the chassis leg Quote Link to post Share on other sites
Xpect Posted December 21, 2013 Share Posted December 21, 2013 May I hijack this thread, I want a G6 box for long now but I want to know if there are LSDs available for that and if the final gear can be changed for a bit longer one. Quote Link to post Share on other sites
