Hi guys just gone out for a quick photoshoot on the Glanza, got there turned the lights and car off, took photos and then went to go home..
Turned the car on, turned my lights on and my indiglos have stopped lighting up :sad:
What should I be checking first?
Many thanks
Dan
Can you still here them kinda buzzing ? First thing to check would be were its spliced into the loom, see if its a bad connection or whatever.
This happened to mine and i reckon the black box thing had failed internally.
If you have no lights at all then it'll most likely be a fuse in the driver foot area, check the big multiplugs to the fusebox are plugged in properly.
