Adam-Gt- Posted December 29, 2013 Posted December 29, 2013 So my heated rear window doesn't seem to be working The switch on the dash lights up when you press it in but nothing happens I haven't really looked at it properly yet but was hoping someone might be able to just tell me where to look to save me abit of time It's on a 1990 ep82Thanks Adam Quote
Jamie5414 Posted December 29, 2013 Posted December 29, 2013 (edited) If you have a multimeter, You can check between the positive connector on the back window (there may be one or two connectors, one either side of the inside of the window, at the top) and then use the body (not any painted part) as a negative and see if you get a reading when it's on (someone could sit inside the car and press the heated rear window button and if you have the multimeter on the "buzz" setting it should buzz when they are in the "on" position, if they don't then the connector isn't getting power obviously). I'm unsure if they are fused or not? I've never had them go on me so not looked into it really. Edited December 29, 2013 by Jamie5414 Quote
Adam-Gt- Posted December 29, 2013 Author Posted December 29, 2013 Cheers Jamie I'll start there then both my starlets I've had heated windows didn't work Quote
