I have standard shocks with 40mm RSR. Springs
I have a decent gap between my tyre and arch just want to stop it bouncing of the tyre like reduce bounce
I've heard of bump stops but what do I get and how to use ??
Any help would appreciate
Cheers
is your tyre hitting the arch? a bump stop is there to cushion the suspension at full compression... and/or to limit suspension travel.
if your car is bouncing around, then its most likely your shocks are either fooked, or arnt up to the job of dampening the car with the stiffer springs.
