I'm looking to buy new wheels for my glanz I have coilovers but not to keen on rolling arches! Was looking at rota grids or xxr 530/527 but what size width and offset? Cheers guys and gals
Xxr wheels you will struggle because they come in wide sizes and low offsets. Grids will be alright providing you don't go low on the offset.
6.5J width and anything around the 35-42 offset will fit fine.
You can get xxr in a wide range of sizes.
If you done want any arch with I would go anything wider than 7" or lower than et30
i have 16x8j grids et 10, no major arch work needed just folding the lip over in the rear. No problem on the front with 40mm lowering springs
Same as i done just rolled the lip up.. job done..
