Flynn Posted January 11, 2014 Posted January 11, 2014 Trying to change my front brakes and lines but in the process have snapped the hard line behind the connector union......how would a replacement fix onto the hard line that's left (don't really want to replace the whole thing as my bay is tight with a 4age lump in there) hope this makes sense. It's the connector between the braided line and the hard line that I need to replace? Cheers Quote
Gilly Posted January 12, 2014 Posted January 12, 2014 I have a drivers side solid line that runs after the flex line, they are all one piece if I'm not mistaken. which side has snapped? Quote
TurboTobz Posted January 12, 2014 Posted January 12, 2014 (edited) You can get a kit to make hardlines would probably be able to do something with this if you could use one... Edited January 12, 2014 by TurboTobz Quote
Flynn Posted January 12, 2014 Author Posted January 12, 2014 I have a drivers side solid line that runs after the flex line, they are all one piece if I'm not mistaken. which side has snapped? Drivers side! Quote
