rmsnoel Posted January 17, 2014 Posted January 17, 2014 You need to be using the inlet air temperture sensor lads. Corolla manifold should be increasing your mpg. Jamie lad is your oil fresh, if not get her changed, nothing fancy but by fuck it helps. Check your cars warming up properly. Does it feel sharp enough, like is your engine in good nick. Your tank guage isnt divided into four quarters equally if u look one is smaller. I do 40 mile after she reaches the empty line. If you join te1 and e1 in your diagnostics plug your idle will rise then drop and sit happily at /750_800rpm. If it doesnt clean your throttlebody with a rag inside.Id change your sparkplugs first though.. Quote
Jamie5414 Posted January 17, 2014 Author Posted January 17, 2014 Yes mate, It's had a service with Fuchs oil last month, new panel filter in the standard air box and cleaned it all out, running spot on mate only got 40k on the clock, warms up good A few people have said spark plugs to me, i'll take them out and check for condition tomorrow. Cheers for the post noel Quote
