dangeestarlet Posted January 26, 2014 Posted January 26, 2014 Just finishing my loom and the glanza plug is different to the n/a plug, can I just cut both plugs off and match wires up? Or will I need to run a live to the pump from ignition so pump only starts when ignition is on? I don't want to have to go spending more monies on a glanza pump, thanks Quote
Greenmachine81 Posted January 26, 2014 Posted January 26, 2014 Just swap the plug.. everythng will match up no probs.. done it myself :-) Quote
daniel_g Posted January 26, 2014 Posted January 26, 2014 And its the exact same pump by the way, the N/a and the turbo pump, just incase you buy a Glanza one as an upgrade or something !! Quote
dangeestarlet Posted January 26, 2014 Author Posted January 26, 2014 And its the exact same pump by the way, the N/a and the turbo pump, just incase you buy a Glanza one as an upgrade or something !! oh that's good to know as I was going to buy a glanza one just incase the n/a didn't give it enough fuel lol Quote
daniel_g Posted January 26, 2014 Posted January 26, 2014 A 255 would be a good upgrade just incase the N/a one is a bit worn out from being 16+ ?? years old. Quote
