dangeestarlet Posted January 27, 2014 Posted January 27, 2014 So I'm just plugging everything in in the engine bay and I can't figure out which ones for the alternator and one for the starter, I thought I found the battery possitive but if can't be it as there's another plug on the loom right by the connection as shown in picture, so will my battery positive come from the fuse box as there's 2 lugs one for possitive and one for negative with 10mm nuts holding them down, any help and pictures would be great , thanks Quote
Stu Posted January 27, 2014 Posted January 27, 2014 That should go to the alternator post. To check, using a multimeter check for connectivity between that post and the largest diameter wire on the alternator plug as they join inside the loom about 3/4 of the way back to the fuse box. The starter post cable runs directly from the battery positive and is a single wire. I've got a EP82 charge circuit separated out if you need photos. Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 So that one goes to the alternator and the plug plugs into the alternator but I have no other wires like that with the loops , eg for starter or possitive battery terminal , I'm so confuse lol it's doing my head In Quote
davehart Posted January 27, 2014 Posted January 27, 2014 That is the power and ground for the Alternator. Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 Right ok, so I'm missing wires for starter and possitive battery terminal , is there separate a seperate loom for positive like the negative loom? Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 So I found a diagram which looks like the positive terminal goes to the fusebox as I thought , so on the starter there's a post for a wire with a loop to go on then there's a little spade one, which one goes to the starter post earth or positive? Quote
davehart Posted January 27, 2014 Posted January 27, 2014 The positive battery terminal should be part of the main loom. Have they cut the end off and just left the wire without a terminal on the end anywhere? Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 There don't seem to be any wires cut off anywhere :s here's a starlet diagram I have Quote
davehart Posted January 27, 2014 Posted January 27, 2014 There should be a section that runs out of the loom that goes to the fuse box which has the positive terminal on and the diagnostic box. Quote
Stu Posted January 27, 2014 Posted January 27, 2014 The starter post wire is generally a separate single wire and is sometimes only loosely wrapped with the loom. Looks like that's the one that's missing. Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 The starter post wire is generally a separate single wire and is sometimes only loosely wrapped with the loom. Looks like that's the one that's missing.ok cheers any is that a live or a negative? Quote
Stu Posted January 27, 2014 Posted January 27, 2014 Ok here you go - this is from a EP82 4efte: Alternator plug top left - alternator post terminal has been cut off as I needed it for a conversion but you can see the wire and how it joins back to the white wire from the alternator plug anyway. This then runs to the fuse box. Starter wire - runs independantly of other wiring straight to the starter post. Note: There are no ground wires to the alternator as said incorrectly said above, or to the starter motor for that matter. Quote
dangeestarlet Posted January 27, 2014 Author Posted January 27, 2014 Ok thanks for your help il check it all in the morning Quote
Zeldoz Posted January 27, 2014 Posted January 27, 2014 I don't think I missed anything as it all came out together.I'll check the grass around the shell for any escapee wires that I overlooked when boxing it up! Sorry bud! Quote
