jtaylor1990 Posted January 31, 2014 Share Posted January 31, 2014 Hi guys.Have a leaking crankshaft oil seal and doesnt look fun to replace :/ anyone changed on before, special tools to remove the crank pulley? Thanks, Josh Quote Link to post Share on other sites
Azz Posted January 31, 2014 Share Posted January 31, 2014 (edited) drop drivers side engine mount.remove plastic cover.take of cambelt, dont forgert to mark everything up for timing.Undo the bolt that holds the crank puley on can be a pain to crack off though.Small pulley puller makes life easier to remove the pulley.take off oil pumpreplace sealre seal/fit oil pumpbuild everything back up. the seal are only a few quid. all being well its easily done in a couple of hours Edited January 31, 2014 by Azz Quote Link to post Share on other sites
rmsnoel Posted January 31, 2014 Share Posted January 31, 2014 Does the sump need resealed at the bottom of the oil pump as well? Quote Link to post Share on other sites
jtaylor1990 Posted February 2, 2014 Author Share Posted February 2, 2014 Nice one thanks. I'll get a seal from ID works as they are cheap on there. I have a workshop so should make it easier. Think I'll polybush the mount whilst I'm there too. Quote Link to post Share on other sites
jtaylor1990 Posted February 2, 2014 Author Share Posted February 2, 2014 (edited) I've had the Crankshaft pully off before and made sure I cleaned the thread up and the pulley so will be a piece of piss to remove. Its just the crankshaft sprocket itself that I'm concerned about in case I break any teeth off due to it being overtight Edited February 2, 2014 by jtaylor1990 Quote Link to post Share on other sites
hookie663 Posted February 2, 2014 Share Posted February 2, 2014 Personally I tink it's a total cunt of a job llf tink jay will second that lol Quote Link to post Share on other sites
jtaylor1990 Posted February 2, 2014 Author Share Posted February 2, 2014 Lmao!! Yh I know its gonna be wank. May order another Crankshaft sprocket just in case Quote Link to post Share on other sites
