Adeeb1395 Posted February 3, 2014 Posted February 3, 2014 as said in the topic how to do it?the mods i hv are:4efte throttle4efte injectors4efte fuel rail4efe MA-5960 ecu (sadly mine didnt came with 5efhe ecu)corolla 100 dual core radiator4efe fuel pumpand everything stock from 5efhe enginegoing to do 2.25inch exhaust and decat it.My plan is to go turbo but before that want to drive it as fastest na.any suggestion mates? Quote
cherrye10 Posted February 3, 2014 Posted February 3, 2014 Skim and port the head as far as it alliws. And get ecu reprogrammed Quote
AdamB Posted February 3, 2014 Posted February 3, 2014 (edited) Raise the compression, raise the rev limiter. Don't touch the cylinder head though, the ports are already way too large as it is, I dare to say you will even gain power if you made the ports smaller due to the increase in velocity so get better cylinder filling. Depends on your budget really though, could go ITB's, change the cams, change pistons etc. Edited February 3, 2014 by AdamB Quote
rmsnoel Posted February 7, 2014 Posted February 7, 2014 I would fit smaller injectors and start from there Quote
