Somone was after this information before and I just found it in the manual while having a read this morning, useful to know.
Copied straight from manual
Toyota Recommended Oil pressure max/min
ENGINE OILING
ENGINE LUBRICATION SYSTEM
Crankshaft-driven oil pump provides pressurized engine
lubrication.
Crankcase Capacity
Crankcase capacity with oil filter is 2.9 qts. (2.7L).
Oil Pressure
With engine at normal operating temperature, oil pressure
should be at least 4.3 psi (0.3 kg/cm) at idle and 36-71 psi (2.5-5.0
kg/cm) at 3000 RPM.
I checked mine last night and at idle its about 15psi and at 3000rpm around 50psi. :p
Edited by Taggy
ENGINE OILING
lubrication.
Crankcase Capacity
Oil Pressure
kg/cm) at 3000 RPM.
I checked mine last night and at idle its about 15psi and at 300rpm around 50psi. :p
the figre you have got is from cold isnt it
