difference between EP82 and EP91 sensors etc
Looking to get this glanza running and have come in to a slight problem. The engine is from a GT and the loom from a Glanza, on looking it appears there seems to be some difference between the connections to some sensors and alternator etc.
Anyone have any ideas of the actual sensors that are different?
At the moment I have the coolant temp sensor and alternator.
There the only ones.... As far as im aware...
I believe the change was All GT and Pre-Facelift Glanza then changed on Facelift Glanza....
Fusebox is completely different and wiring loom going thru firewall in different arrangements!
But the two coolant temp sensors and A/T are the only differences I think!
Sweet, thanks lads :)
As said, all I have found is just the two mentioned so hopefully that is all :)
The engine is from a mk2 GT, would this and the glanza use the same TPS?
Fitted gt engine to mine at summer ther wif glanza loom no probs only ting I did was change the thermoset house over from glanza engine to the gt engine? Had no problem wif altonatter lik or anything else I do know the inlet manifold gaskets r different and the inlet manifold to
  • 1 year later...
