Aamir Posted February 13, 2014 Posted February 13, 2014 Hi, i'm looking for a fuel pump for a Toyota Starlet SR 1998. I'm not sure if one from a Glanza will fit or not but here are some pictures of the plug on the end... Thank you
rob_bower Posted February 14, 2014 Posted February 14, 2014 A glanza one will fit in the pump cradle and the small plug on top of the shiney pump part is the same. The plugs on the cradle are different though. I might have a spare sr pump somewhere.
Liam_D Posted February 15, 2014 Posted February 15, 2014 I have a standard glanza pump if you are still needing one.
Aamir Posted February 15, 2014 Author Posted February 15, 2014 WA glanza one will fit in the pump cradle and the small plug on top of the shiney pump part is the same. The plugs on the cradle are different though. I might have a spare sr pump somewhere.I'm after one that will just plug into my current wiring loom because I don't want to mess about and cut random wires...I have a standard glanza pump if you are still needing one.Could you possibly send me a picture of the end of the plug to see if it plug into my wiring loom as I have two at the moment which are no good to me
