I need to source a crankshaft pulley for my ep91, does anybody know where I can get one or is it something I would have to go to toyota for? I was also wondering as the 4efe is found in corollas will those pulleys fit? Or even the 5e pulleys?
Grateful for any advice, apologies for any naivety.
Thanks Sam
  • 5 months later...
is that the harmonic damper pulley as used on the 4e-fte and the 5e-fhe? if it is and you find out where to get one let me know.
if it is the harmonic damper pulley dont buy the solid damper off the 4e or 5e or the alloy one advertised on ebay and other companies.
heres why http://www.atiracing.com/products/dampers/damper_dinan.htm
