Definitive answer? 5efe on 4efe ecu?
Does it run if you change over all the ignition and other bits and pieces from the 4e onto the 5e?
If it does run, does it run well/ good enough to drive?
Is there a 5e ecu that I can just swap around without changing wiring but keeping sensors and ignition setup?
The 4EFE ecu I'm not sure I would use, because of the larger capacity of the 5E you need more fuel to get the correct mixture with the larger volume of air. The 4EFTE ecu will be ok to use since its a turbo and has more fuel flow.
