micrat Posted March 1, 2014 Posted March 1, 2014 Afternoon you beautiful people...Am in the process of repairing 80% of my little starlet...it looks like a fat birds thighs its so dimpled.Question is, how do I safely remove the outer of the 2 weatherstrips on the doors (where you roll the window down...say where your arm would rest if you were cruising lol)Just thought I would ask before I started levering things...didn't know if it travels behind the mirror or anything.Cheers in advance...Mike. Quote
JamesD89 Posted March 1, 2014 Posted March 1, 2014 if you mean the lower window seals should just peel off mate Quote
micrat Posted March 26, 2014 Author Posted March 26, 2014 (edited) Sorry for slow reply - and thanks for the advice... Turns out - roll down the window, gently pry the outer strip vertically upwards, if you try pulling at it you will likely break the little plastic clips it slots into Edited March 26, 2014 by micrat Quote
