miss fire / black smoke / rough on boost
Hi guys picked up a glanza today. Seems to run sweet as a nut up until high boost.
Its got a fcd and fpr setup.
Runs approx 0.9 bar, little less in lower gears.
I can sort of avoid it by using 3/4 throttle but if I boot it, it kicks out black smoke and feels bit like 3 cylinders. It will missfire a bit under full throttle then get really bad past bout 6k
The fpr is at 3 bar, the fcd has a sticker on the adjuster that says close? So cant see what its set to
Any ideas?
Thanks
