Adeeb1395 Posted March 2, 2014 Posted March 2, 2014 i want to use 4efte ecu so can i use stock 4efte piston and 5efhe rods with it??? what would be the comp??? and what mm gasket i need to use?? help pls!! Quote
turbo Grant Posted May 30, 2014 Posted May 30, 2014 You can use 4efte pistons and a fte head gasket. That would give you near stock fte compression depending on if head and block have been skimmed. Head gasket thickness all depends what you want to do with the car really Quote
Adeeb1395 Posted May 30, 2014 Author Posted May 30, 2014 if i use fhe rods and fte pistons with 1.2mm gasket would the stock 4efte ecu able to operate?? i mean the comp would be like 100% 4efte?? Quote
