Dean_mc88 Posted March 7, 2014 Posted March 7, 2014 So this is what my current turbo looks like and wanted to change the housing for a new one , is it a simple job or will it require more than just replacing the housing. It seals fine but looks gash !! Quote
russ78 Posted March 7, 2014 Posted March 7, 2014 (edited) it easy to a point....... undo the clamp that holds exhaust housing on move exhaust housing out the way. then here comes the hard part you need to remove the big circlip that holds the turbo housing on it will have two holes either end of the circlip you need a very heavy duty set of inbound circlip pliers take this out and the housing will come off then just do exactly the same in reverse to put it back together Edited March 7, 2014 by russ78 Quote
Dean_mc88 Posted March 7, 2014 Author Posted March 7, 2014 Cheers mate I build rather big oil and gas structures so im no stranger to stripping down motors etc however when it comes to something like this im a bit scared to undo something then it needs balancing etc if it is just a straight swap then boom easy fix. cheers for the reply mate Quote
russ78 Posted March 7, 2014 Posted March 7, 2014 no worries about balancing the housing has a locating pin it can only go on one way Quote
Dean_mc88 Posted March 7, 2014 Author Posted March 7, 2014 you beautiful person cheers mate buzzing now that my turbo wont look shite Quote
russ78 Posted March 7, 2014 Posted March 7, 2014 just be careful once the housing circlip is off as its easy to damage inlet wheel if you bang/scrape it on the housing whilst separating it, a nice steady hand and be gentle....... Quote
Dean_mc88 Posted March 7, 2014 Author Posted March 7, 2014 cheers again mate il let you know how I get on Quote
