euanTbone96 Posted March 8, 2014 Posted March 8, 2014 (edited) hi, my car is holding back when i go to accelerate its sounds as if its miss-firing. only really when its under pressure like going up through boost or just hard accelerating. feels like the car has little power too... and ideas what this may be? thanks Edited March 8, 2014 by euanTbone96 Quote
Baz-GlanzaV Posted March 16, 2014 Posted March 16, 2014 Think I'm experiencing the same only noticeable in 3rd though as soon as you plan foot it kind of hesitates but engine note gets louder between 3-4k rpm and then climbs again after passing 4k! Hoping it's simple fix. Quote
natalie_fuller Posted March 16, 2014 Posted March 16, 2014 Ok I had a similar problem to this a while back. After changing the leads plugs dizy cap air temo sensor fuel filter injections vac lines ect ect. Well I had fitted a new lambda sensor a year before. This had gone faulty. I decided to give it another shot and changed the lambda and that sorted everything out. Start with rhe cheapest and work your way through it until all is well Quote
gorganl2000 Posted March 17, 2014 Posted March 17, 2014 (edited) also check your map sensor and the connectionshave you done a diagnostic? Edited March 17, 2014 by gorganl2000 Quote
euanTbone96 Posted March 18, 2014 Author Posted March 18, 2014 nope not done a diagnostic! think I've fixed it, i changed the rotor arm and distributer cap and seems to be fine now:) Quote
