chigs123 Posted March 11, 2014 Posted March 11, 2014 Just finished doing my ep91 n/a 4efte conversion and have quite allot of plugs left over as I don't have ac or power steering or abs. Now the car came with a half size rad and slimline fan so none of the plugs fit to the fan so I'm looking for some pictures and help locating the plug for the fan then I can use spade connectors.. Any help will be appreciated Quote
Stu Posted March 11, 2014 Posted March 11, 2014 The radiator fan plug is usually run from the same loom as the headlights and its a two pin plug. Its usually easily spotted as its got large diameter cabling. Quote
chigs123 Posted March 12, 2014 Author Posted March 12, 2014 Cheers bud I'll have a look tomorrow, there's about 5 plugs around that area and assume they're for the aircon etc so I'll just look for the 2 pin Quote
dangeestarlet Posted March 12, 2014 Posted March 12, 2014 I never found it when it was on mine buddy , think you need a glanza fan as the n/a and gt plug are different to the glanza loom you had off me Quote
Stu Posted March 13, 2014 Posted March 13, 2014 Take a photo or two if you can, will help us spot it for you Quote
chigs123 Posted March 13, 2014 Author Posted March 13, 2014 I'll try and get some pics up tomorrow, and I have an aftermarket slimline fan so it has no plug so just wanting to cut the plug off and use connectors once I find plug :/ Quote
