1990timeismoney Posted March 11, 2014 Posted March 11, 2014 Hi all.had a blitz boost controller installed for a while but not really had the best time to get it set up on the rollers.Does anyone have any settings I could try to run .8 on a td04 setup Any help appreciated Quote
1990timeismoney Posted March 30, 2014 Author Posted March 30, 2014 Bump anyone got one installed I could run a base setting from Quote
RobSR Posted March 31, 2014 Posted March 31, 2014 It's hard to say as all cars are different and the boost control is a ratio not just setting it at .8bar. Start with the ratio low then build it up I till you hit the boost level you want. Once you've done that, do the same with the gain. Usually set that so it boost to 0.8 without spiking, or you could set it lower to get a more progressive boost curve. Whatever you prefer. Quote
1990timeismoney Posted April 2, 2014 Author Posted April 2, 2014 Ok thanks for the reply so if I set the gain to a rough boost setting and use the gain starting low and adjust till I get it to meet the target and hold Quote
AdamB Posted April 2, 2014 Posted April 2, 2014 Set the boost setting ( it's a percentage on the blitz units) first till you get the desired boost of 0.8 bar. Then raise the gain from 0 up till when it starts spiking then back it off a few percent, but all depends on how you want the boost to come in really as Rob said Quote
