what do you think guys? can i get centre caps over the front wheels?
Try it? and this is what mine start off like and now it looks bit like glanza
Wheels look tidy mate personally i'd get them door strips off it will break it up and make the wheels the focal point.
James
thanx. hmmmm i kind of like the strips. wheels looks better when car is moving. can i get some caps for front wheels?
possibly. I had a similar problem with mine a while back. You will want ones that dome outwards. something like these:
http://www.ioffer.com/i/avs-wheel-center-caps-d1-62mm-d2-65mm-1set-4pcs-554264080
Just do a bit of measuring to see what fitment you need.
Check out others on ioffer.com, its one of the only places I could find a good selection of them in different sizes (replicas however).
New wheels look good. :thumbsup:
Chris.
Chris.
thanks. There oem steelies lol
metal dust caps, I think them are for alloys pal.
Primarily they are Yeah :) but if the pcd bore is the right size they should fit as they click in. Sorry!
Anyway, I'm not sure if the metal dust caps come on the front? Knock the rear one off and try for size.
I'm sure you can get them new from Toyota if they do fit.
Edit: didnt come on the front by the looks of things here:
http://toyotamarket.ru/eu/121550/006/2/
Link worked on mobile ok. Heres the image anyway:
Edited by vizzioarts
vizzioarts I was thinking because of them being oem they don't because I've not seen any have one. link don't work pal,
gave the wheels a light sand down and used hammer-rite paint. it says no primer required. paint on metal or rust lol.
