andy91145 Posted March 17, 2014 Posted March 17, 2014 I have an external wastegate set up with screamer. I'm meant to be running spring pressure which is an 8psi spring I'm getting a ebc soon. What sort of things am I meant to be checking? I might add that the wastegate opens at like 4.6psi and there you get the scream :S Just out of curiosity where so people run the vacuum line for their boost gauge? Help would be much appreciated!! Quote
Ollieh17 Posted March 17, 2014 Posted March 17, 2014 My boost gauge is t-pieced off the map sensor. Have you got the vac hose connected to the turbo housing then to the side port of the wastegate? Quote
5e colin Posted March 17, 2014 Posted March 17, 2014 when u fitted the wspring u mightent off sealed it propper and have a small leak ??? Quote
andy91145 Posted March 17, 2014 Author Posted March 17, 2014 My boost gauge is t-pieced off the map sensor. Have you got the vac hose connected to the turbo housing then to the side port of the wastegate? May be a stupid question but where is the map sensor? Yeah I've got that pipe on when u fitted the wspring u mightent off sealed it propper and have a small leak ??? I haven't opened it the spring was in from new Quote
