Banbury Glanza Posted March 20, 2014 Posted March 20, 2014 As above, my car is in the garage and will not start. The machanic (good mate) is a bit mythed by it all, he says it will start if you put a live on the fuel pump, but can't trace the relay or any blown fuses. He thinks it's a problem with some sort of little ECU ?? I'm also useless with cars haha so if this makes no sense sorry. Any help greatly appreciated Cheers Todd Quote
TimD Posted March 21, 2014 Posted March 21, 2014 http://www.mearcat.com.au/docs/EP82%20Starlet%20Wiring%20and%20Connectors.pdfPass that along to your mechanic, he should be able to sort it from there.There is a relay which controls the fuel pump tucked underneath the dash. Quote
nikhilkamdar12 Posted March 21, 2014 Posted March 21, 2014 There one of these PDF specifically for the Glanza? Quote
McGeary1 Posted July 19, 2015 Posted July 19, 2015 Did you solve your problem? I have no fuel pump until I connect a live from the inside fuse box 😟 sounds like the same issue I have Quote
Flaminsam Posted July 19, 2015 Posted July 19, 2015 I think the fuel pump relay is located near the glovebox area. Possibly above it as that's where it is on a gt. it has five wires going to it and it's dark green from memory. As for the "switch" for it, it's signal comes from the ecu. "FC" on connector number 2 becomes an earth when the ecu detects a cranking signal from the distributor pick up. Another thing to check is the earth point on the inlet manifold that goes to the idle control valve. This is one of the main earths for the ecu and could play a part in the starting issue. Quote
