Lukee Posted March 20, 2014 Posted March 20, 2014 Hello all, i just brought an N/A , My brother and friends all own the turbo versions. I really like the way they look, could anyone list some parts that are just a remove and replace to fit my N/A please ? Quote
dangeestarlet Posted March 20, 2014 Posted March 20, 2014 Tailgate, rear bumper, skirts,then( bonnet headlights and front bumper )must all be done together as they don't mix and match, interior Quote
morgey Posted March 20, 2014 Posted March 20, 2014 The interior panels are a direct replacement. Seats door cards plastic trim.Glanza brakes bolt up and are bigger.Rear disc conversion can be done. (Calipers with carriers, discs with bearings, brake lines and handbrake cables needed) Strut braces (not the 3 point ones though) Quote
Lukee Posted March 21, 2014 Author Posted March 21, 2014 The interior panels are a direct replacement. Seats door cards plastic trim.Glanza brakes bolt up and are bigger.Rear disc conversion can be done. (Calipers with carriers, discs with bearings, brake lines and handbrake cables needed)Strut braces (not the 3 point ones though)thankyou morgey, are the rails etc straight swap? my brother said i can have his standard ep82 ones but are they different to the ep91's? Quote
morgey Posted March 21, 2014 Posted March 21, 2014 Ep82 interior plastics are different and won't fit ep91 The rear bench is a straight swap and the fronts will need a small bit of modifying to the feet to fit. Run a search for a guide of what needs doing to fit ep82 seats in an ep91 Quote
