Dusty Posted March 21, 2014 Posted March 21, 2014 (edited) Hey all so I took my 97 v off the road in Feb as it needed an mot but needed some work done to pass, the battery went dead and won't start, I had an old school hks fuel comp and Thot while I had the battery out I'd plug it in but realised I didn't have the map sensor so put it back to standard ecu put battery in and all the normal dash lights and cd player is coming on but the car will not turn over, had a prop with that battery not starting the car before but charged it up and went fine but nothing this time even had jump leads onit but still nothing, got me and my mate baffled and he usually can fix most problems I've had before any one know what could be stopping her from turning over? Thot maybe a sticky starter motor are they knowing to jam? Still fairly new to starlets just wanting to get her mot'd and get my td04 on and remapped if any one has any suggestions Plz let me know what you think CheersDusty Edited March 21, 2014 by Dusty Quote
Gainzy Posted March 21, 2014 Posted March 21, 2014 My first thought is starter motor, enough fuel in it I would imagine! Sounds like it needs a good run out oil change etc I doubt you plugging that hks ecu in did any damage check the plugs over check lead clips, good luck Quote
dangeestarlet Posted March 21, 2014 Posted March 21, 2014 Put the car in 4th gear let hand brake down and push it like a metre or 2 to unsieze starter Quote
Dusty Posted March 21, 2014 Author Posted March 21, 2014 My first thought is starter motor, enough fuel in it I would imagine! Sounds like it needs a good run out oil change etc I doubt you plugging that hks ecu in did any damage check the plugs over check lead clips, good luck Thought it may be that, it's on my mum's drive bit of a cunt to get out maybe just have room to try that, there is fuel isn't it could maybe try putting a can isn't it just to bring the level up a bit and try get the starter motor moving will let yous know cheers guys Quote
turbo Grant Posted March 21, 2014 Posted March 21, 2014 Tried giving the starter a smack with a hammer? Quote
Dusty Posted March 21, 2014 Author Posted March 21, 2014 Tried giving the starter a smack with a hammer?Isit possible to get a hammer in near it from above I could just get to it with my hand earlier when I was looking over everything Quote
mech5107 Posted March 22, 2014 Posted March 22, 2014 What's the voltage when trying to start it? Quote
Dusty Posted March 22, 2014 Author Posted March 22, 2014 What's the voltage when trying to start it?Not sure mate would need to gets a meter to read the volts what kind of reading should I be looking for? Quote
