Just a quick one guys.
I've got an ewg TD04 kit (minus the turbo which I still need),with an 0.8 bar spring at the moment.
The member who I bought the kit off was previously running the setup on his car, with just an uprated fuel pump, it made 187bhp and he said fueled perfectly - He had an AEM wideband to keep an eye on things.
I'm planning to run 1 bar eventually with my jam fcd and rrfpr, but would I be ok running 0.8 bar safely with just an uprated fuel pump - I don't have a wideband though.
I'm also looking for a wideband but dont really know much about them! Mine was mapped at 2.8bar of fuel pressure running up to 1.1bar on a TD04 but I currently have a map sensor issue so wanted to make sure that the fueling was correct and not cooking my pistons!
Brendon
Brendon
Was that with an fcd and rrfpr, or with a piggyback or standalone Brendon?
Am using an aem going strong over 2 years now I can't fault it, u will need to weld a bung on your exhaust
How much is the aem one?
I ran mine at 0.8bar fine with a standard pump and no wide band. Granted it was only for a few months until I could afford management.
