Got a 4e block thats perfect for forging could even possible hone it and re use and standard fitting
are any of them the none turbo block, guys i need the insult for the oil filter, as im taking my oil filter housing off and running a oil cooler straight off the block on the sandwitch plate and my turbo feeds coming off that, i did this on my 5e works great and looks much more tidyer
wining to pay good price for it if you can get it out, if i rememeber right it has holes in the end of it when you take the filter off just put a screw driver in thats a snug fit and twist out
you cant buddy the centre bolt if i remember right its 19mm and is not male on both ends, its basically a bolt with a hole in the centre and at the sides, if you take one off your spare engine your see what i mean mate, hence why i need the insert from a efe or 5e
Edited by danny-baby
