JayJ Posted April 3, 2014 Share Posted April 3, 2014 (edited) There's not much info about EMU and how to plug it in your Glanza, so here's the chart I made for myself to ease the soldering EMU universal harness and EP91 extension harness(or direct to car loom) together.I'm not sure, if I missed something, so feel free to comment&correct, but with this you should be able to get the car running :-]Also, if you have other useful info regarding EMU please share it hereEmanage Ultimate pin connect ECU pin5, ignition input signal CH1 ecu 26plug, 2212, ignition output signal CH1 car 26plug, 2215, airflow1 voltage input car 16plug, 216, TPS input splice 16plug, 1017, injector input signal CH1(1&3) ecu 26plug, 1218, injector input signal CH2(2&4) ecu 26plug, 2522, airflow1 voltage output ecu 16plug, 223, RPM input signal splice 26plug, 324, ECU ground splice 26plug, 2425, ECU power splice 12plug, 730, injector ground splice 26plug, 1332, knock signal 1 / water temp splice 16plug, 14/433, crank angle signal input splice 26plug, 434, injector output signal CH1(1&3) car 26plug, 1235, injector output signal CH2(2&4) car 26plug, 2538, knock signal 2 / intake temp splice 16plug, 14/339, cam angle signal input splice 26plug, 540, vehicle speed signal output ecu 12plug, 1141, vehicle speed signal input car 12plug, 11 Edited April 3, 2014 by JayJ Quote Link to post Share on other sites
BIGGFOOT Posted May 4, 2014 Share Posted May 4, 2014 Any settings for emange blue? Also where can I get a harness and sensors from Quote Link to post Share on other sites
