Vicep82 Posted April 4, 2014 Share Posted April 4, 2014 Last night I finally got my ep82 back on the road from gearbox problems was sitting tthere for 3 months took it out after 3/4 hours of driving I came on boost then felt like a fuel cut but a mate of mine was behind me and said it shot a flame Then the overheat and knock sensor came on and smoke pouring out of the bonnet the wires lleading to injectors were friedAny ideas on why this happened would be awsome cheers Quote Link to post Share on other sites
symoep91 Posted April 4, 2014 Share Posted April 4, 2014 Check all coolant hoses? Or even the coolant itself? Quote Link to post Share on other sites
richardc9052 Posted April 4, 2014 Share Posted April 4, 2014 Sounds like lack of oil or oil pressure, did the smoke smell really bad? Quote Link to post Share on other sites
Vicep82 Posted April 5, 2014 Author Share Posted April 5, 2014 Yeah had a funny smell very thick Quote Link to post Share on other sites
richardc9052 Posted April 5, 2014 Share Posted April 5, 2014 take the rocker cover off and smell in there. there should be obvious damage like chipped cams but the smell will give it away. Also check oil level. If it wasnt the engine that caused the wiring to melt which would have caused the overfueling/flame and bang then you have an electricl fault. Maybe someone replaced a fuse with a higher rated one? Im clutching a straws but if you take the rocker off and you cant stand the smell the head is fried. Ta few years ago this happened to me and the smell was so bad when i opened the fuel cap i nearly threw up.. The reason it happened was i had swapped an fe sump onto an fte engine for reasons i cant be bothered explaining and did not know there was a difference in pickups. didnt have enough oil pressure to reach the head. Quote Link to post Share on other sites
Vicep82 Posted April 5, 2014 Author Share Posted April 5, 2014 Smells fine I the headGot under the car and the big wire to the starter was off aswell Quote Link to post Share on other sites
Jim* Posted April 5, 2014 Share Posted April 5, 2014 did it continue to run or cut out? check your block for any holes just to be on the safe side. Quote Link to post Share on other sites
Vicep82 Posted April 5, 2014 Author Share Posted April 5, 2014 Put a new loomDrove it homePulled loom apart wire from inside fuse box to ground wire on plemum was burnt out Quote Link to post Share on other sites
richardc9052 Posted April 5, 2014 Share Posted April 5, 2014 (edited) That's strange!?Edit: you engine is ok then? good! Edited April 5, 2014 by richardc9052 Quote Link to post Share on other sites
