Depending how thick the wire is / big the multi plug is you can route it through the throttle cable grommet in the bulkhead just behind to the left of the inlet mani!! Dash can stay where it is :)
Same wideband as mine. I ran my cables through the old a/c grommet as I removed the evaporator from behind the glovebox. Don't forget to set the wideband up first before plugging in the sensor. ;)
