Item For Sale: Prosport Peak/Warning stepper motor gauges, oil pressure, oil temp, boost
Item Condition & Description: Arguably the best dials on the market, i bought them as i used to do a lot of track days and knowing the cars engine temps etc was critical, not only are these gauges cool to look at, they potentially save your engine on or off the track, you can set warning alarms to go off at set limits and what has saved me loads of times was the warning on the boost sensor for when the car was over boosting without me realizing.
The same goes for the oil pressure and oil temp, you can set peak warning levels. On top of the you can recall what the peak readings were on your last run so you can see what limits you are reaching.
Cracking bit of kit and easy to install, includes the sensors, all wiring and oil filter sand which plate.
You can also select the illumination colors and they do a cool warm up test when you turn ignition on, i have set mine up for white, but you can set them so they goto red/amber for the night time when you turn your lights on.
Price: £120
Payment & Shipping Details:
Edited by Taggy
Oil pressure what is it measured in?
And boost what does it measure up up?
And what sizes gauges are they 52 or 60mm
Thanks
Chand
Oil pressure what is it measured in? PSI
And boost what does it measure up up? bar
And what sizes gauges are they 52 or 60mm sure there 52mm but id double check
Thanks for reply Shaun
But boost is in bar but what 2 bar or?
But he could of posted that there sold I would of taken them
Yeah I've got cheap ones I bought years ago but need some thing more accurate and these would of been perfect
Taggy these gone then?
I was buyin them but he said last night they had been sold
