spud94 Posted April 6, 2014 Share Posted April 6, 2014 Got a emanage blue and bought a field harness f here but it dosent plug straight into the ecu need to no what wires to cut in to, to add the other plugs Quote Link to post Share on other sites
richardc9052 Posted April 6, 2014 Share Posted April 6, 2014 Do you have a glanza or a gt? The field harness is different for both as the ecu has 3 connections on a glanza and 2 on a gt. The emanage needs wiring into the harness that then should plug straight in between the loom and ecu if you have the right one Quote Link to post Share on other sites
spud94 Posted April 6, 2014 Author Share Posted April 6, 2014 I have a GT EP82 and the field harness has 2 plugs on one side but they don't plug into my emanage blue? Quote Link to post Share on other sites
richardc9052 Posted April 6, 2014 Share Posted April 6, 2014 No your supposed to wire the emanage blue into the harness and then plug the harness between ecu and loom.. Quote Link to post Share on other sites
