Ballyhannon Posted April 6, 2014 Share Posted April 6, 2014 Folks I need advice. I am running a 1.5 Paseo engine using i think an ECU from 1.3 EP91 (89661-10181. 211000-6571). I did not do the engine change. It seems to run Ok just feel it is short of power. Would there be any difference in the two units. And if so what is the part code for the Paseo unit. Quote Link to post Share on other sites
5e colin Posted April 6, 2014 Share Posted April 6, 2014 keep your stock ecu and use a wideband and a fpr to get the afr good you will run it to several isseus trying to fit the 5e ecu in your p9 Quote Link to post Share on other sites
Ballyhannon Posted April 6, 2014 Author Share Posted April 6, 2014 What I am asking is if I fit a 1.5 ecu to my 1.5 engine will it perform better than the 1.3 ecu it is currently running on. Quote Link to post Share on other sites
5e colin Posted April 7, 2014 Share Posted April 7, 2014 ha yes it would run better for sure but im very sure you would nead to cut and switsh wire around on the ecu sockets what car is it going into ???? i have a few diagrams that might be handy to ya Quote Link to post Share on other sites
Ballyhannon Posted April 8, 2014 Author Share Posted April 8, 2014 The engine is in a 1999 ep91 sr starlet. Quote Link to post Share on other sites
Greenmachine81 Posted April 8, 2014 Share Posted April 8, 2014 Were u live man? Quote Link to post Share on other sites
