Just seen your other thread and how your running 5bar of pressure. Set it back to 2.3/2.4 on idle.
EDIT - The JAM Ecu controls the fuelling not the pressure, most are designed to work with the pressure set at standard. So either put the standard fpr back on, or turn the Sard one down as per above.
Edited by RobSR
just read your post before this one rob, thanks i keep getting mixed up with pressure and fueling, just to be safe from stopping ti running lean, shall i just put it on 3 bar on idle?
It won't run lean as you've got the JAM ecu in it. Standard pressure. As its been running so high, reset the ecu aswell once you've done it. Unplug it for 30mins or leave the battery off for 30mins.
