Basically be driving and the car will always pull to the left sometimes a little sometime not at all but other times really badly... then under braking it seems really twitchy and I've got to control it under braking otherwise it'll go on its on demise....? Done tracking aint that.... noticed one wheel the nsf has no spigot ring but the other front does... ? Amy ideas
try checking the camber (decent alignment center can do this), one side could be more than the other as theres a slight bit of movement in the shock mountings.
also check that the handbrake on and isn't pulling slightly on one caliper
Il Check what the camber results were on 4 wheel alignment. .. and check rear brakes. .. front discs should be fine... think maybe the rears... what about wishbone bushes???
