-Engine
APEXi Power Intake Filter
I/C JPerformance customized turbo side
Radiator "Power Cool Papalexopoulos"
Ventilator Spal
OEM radiator hoses
Blow off valve GReddy
Custom oil catch tank
OEM intake manifold and throttle body
Denso injectors
TRD spark plug wires
NGK iridium spark plugs
Blitz oil cap
Custom baffled oil pan
Magnetic sump plug
Head ported and polished
Oversized valves, changed valve guides and valve seat inserts
Upgraded valve springs
Solid Shimless buckets
ARP 4A-GE head studs
Custom billet cams
OEM 4E-FTE Headgasket (The only one, i had available)
75mm Vitara pistons, japan made
Custom forged connecting rods, with ARP2000 3/8" bolts
ARP main caps bolts
ΟΕΜ oil pump
OEM water pump
ΟΕΜ oil filter
Walbro fuel pump
Polybush rear engine mount
Custom exhaust manifold
Garrett turbo (T25 flange)
External Wastegate 38mm
Custom exhaust system 70mm
-Drivetrain
GT Gearbox
Limited slip differential
GT axles
Custom 6-puck clutch and pressure plate
Custom shortshifter
-Suspension and geometry
Coilover D2 suspension, "street" type
Front anti-roll bar 20mm
Back anti-roll bar 16mm
Custom lower arm bar
Custom front 3-point strut bar + chassis strengthening bars from top-mount to lower arms
Custom rear 3-point strut bar
Custom adjustable panhard rod, polybushed
Polybushed controll arm
Whiteline caster kit
Rear camber kit
Polybushed rear arms
-Wheels/tyres
Racing Beat RB-02 15χ6,5 ΕΤ32
Bridgestone Potenza Adrenalin RE002
-Brakes
Nissan Sevro and Pump
Front
Bigger brakes from another TOYOTA
Nissan disks
Hawk HPS brake pads
Stainless steel brake lines
Back
GT ΟΕΜ brakes
OEM disks and pads
-Electonics
Standalone ECU APEXi Power FC "AP engineering" + Commander
Boost controller GReedy E-01
-Exterior
GT look, 040 Super White Τoyota color painted
Retrofitted projector headlights
Side mirrors
Tinted windows
-Interior
Full look GT
Prosport exhaust temperature gauge, with warning and memories
Oil pressure gauge, with warning and memories
Sparco steering wheel
Steering wheel quick release
TRD shifter
-In Car Entertainment
Radio/CD/MP3 Alpine
With a pair of twitters and 4 speakers
Starlets never came in Greece as GT's, so i had to make everything from the beginning.
If anyone of you, will be in Crete (Malia ;) ) this year, just drop me a PM
Some old photos from photobucket
OOoops
What the people asking about
Kinky color painted
The oil pressure after recent engine built, just for reference
>http://youtu.be/bQTykD58Gpw
Maybe i have some more photos the next time.
Edited by trimmata
  • 3 weeks later...
