chrisp96 Posted April 20, 2014 Posted April 20, 2014 Hey folks where do people fit there wideband sensor to is it ok to fit it to the decat pipe as theres already an existing hole to put it in. Thanks, Chris Quote
Mad Mike EP82 Posted April 20, 2014 Posted April 20, 2014 It's should tell you in instruction mate AEM is 36" from turbo I think.You can use the downpipe hole but sensor won't last long there. Quote
mikey4410 Posted April 20, 2014 Posted April 20, 2014 exactly what mike said..........36" from the turbo DO NOT use the deact as you will be frying ure £70+ sensor very quickly dude. Quote
TurboTobz Posted April 20, 2014 Posted April 20, 2014 As above sits perfectly just behind the gearbox at an angle so any water droplets inside the exhaust run off the sensor rather than killing it. It mounts just above 90 degrees from bottom Quote
chrisp96 Posted April 20, 2014 Author Posted April 20, 2014 Ok thanks alot folks much appreciated Quote
