sjbrowning7 Posted April 26, 2014 Posted April 26, 2014 (edited) Removed sump last week, sealed it up, no oil was leaking after resealing and test driving. Changed the oil filter then I started seeing after a little drive, oil leaking. I inspected it and it is quite oily just below the oil filter on the engine where the sump connects and also where the sump meets the crank area. Should I reseal the sump or does anyone think it could be something else? It only started after doing the sump and oil filter. The sump when I took it off had quite a lot of sealer on it around the area I am describing. I don't know if I may have disturbed anything? Cheers Edited April 26, 2014 by sjbrowning7 Quote
fiddlersport Posted April 27, 2014 Posted April 27, 2014 Hello when you replaced the oil filter did you put a small coat of fresh oil on the new oil filter seal (rubber) and hand tighten the filter ? jack the car up and clean it then start the car up while it is jacked up and inspect fro drips ! should be easy fix, hope this helps Quote
sjbrowning7 Posted April 27, 2014 Author Posted April 27, 2014 Yeh I did that with the oil filter. I'll have a look tomorrow then. Quote
