SAitken1 Posted May 2, 2014 Posted May 2, 2014 Hi guys, does anyone know what will drill in to an idler wheel bolt apart from a CNC mill? All the drill bits I have used snapped lol. Cheers Quote
richardc9052 Posted May 2, 2014 Posted May 2, 2014 Your putting too much pressure and not using enough cutting fluid.. Quote
5e colin Posted May 2, 2014 Posted May 2, 2014 wel use a center punch and do that then a 2.5mm drill and gently drill your pilot hole 10mm deep then a 4mm drill then use a lefthanded threadedbolt remover or wa ever ya cal them :) just take your time otherwise you will nead a helicoil !!!!! Quote
SAitken1 Posted May 2, 2014 Author Posted May 2, 2014 Thanks guys, it's not me who's doing it, it's a mechanic in my street. I thought I snapped my timing belt but it was just the tensioner bolt (luckily!). I'm not sure exactly what it is the mechanic is doing but he's been snapping drill bits trying to do it lol. Quote
5e colin Posted May 2, 2014 Posted May 2, 2014 ^^^^^ quick go back and collect your car if he doesnt know how to do a simple bolt removal Quote
richardc9052 Posted May 2, 2014 Posted May 2, 2014 ^^^^^ quick go back and collect your car if he doesnt know how to do a simple bolt removal agreed! Quote
SAitken1 Posted May 2, 2014 Author Posted May 2, 2014 Lol! the bolt has snapped off and fell inside something Quote
SAitken1 Posted May 2, 2014 Author Posted May 2, 2014 I just spoke to my mechanic and he said the bolt is stuck inside the cylinder head and he can't get it out. Quote
richardc9052 Posted May 2, 2014 Posted May 2, 2014 fuck sake.. is the holefor that open ended? if it is hes gonna have to take the head off to clean out any swarf after he drills it out for you. Quote
