karl. Posted May 2, 2014 Posted May 2, 2014 Has anybody fitted a boost control kit to a Apexi Power FC? Is it a matter of replacing the standard valve with the apexi one? Does the map sensor need fitted to the side of the ecu in the 3pin port or does it replace the standard sensor on the bulk head? Quote
pockrockgtti Posted May 3, 2014 Posted May 3, 2014 The solenoid is wired in place of the oem one, the map sensor plugs into the 3 pin port on the side. Quote
karl. Posted May 3, 2014 Author Posted May 3, 2014 The solenoid is wired in place of the oem one, the map sensor plugs into the 3 pin port on the side. Thats great thanks, Any tips on a cheaper option to expensive apexi map sensor? I know the loom is only around 15. Quote
