scottieboi94 Posted May 3, 2014 Posted May 3, 2014 I went to start my car the other just after driving it and my car didn't start first time it's took a few go's to get it to start, ever since then it has been doing this about 50% of the time, usually shortly after I driven it, I have changed the spark plugs and fuel filter and don't think it has made any difference, any idea on what it could be? Before this problem occurs I was driving completely normal the day this happened Quote
brendonware Posted May 3, 2014 Posted May 3, 2014 what ECU are you running? and do you have a fuel pressure reg? maybe its the temperature sensor thats slightly faulty? Brendon Quote
scottieboi94 Posted May 3, 2014 Author Posted May 3, 2014 Jam ecu which was put in about 4 months ago and I'm running a sard fpr What makes you think temperature sensor mate? Quote
Mk3 silver gt Posted May 3, 2014 Posted May 3, 2014 I had the same problem bud, put stock fpr back on because that sorted it for me running a blitz access Quote
scottieboi94 Posted May 3, 2014 Author Posted May 3, 2014 I had the same problem bud, put stock fpr back on because that sorted it for me running a blitz accessDo you know why this fixed the problem for you mate, i have been running this setup for months now and haven't had any issues? Quote
Fozzie Posted May 3, 2014 Posted May 3, 2014 My understanding is that P&P ECUs don't like FPRs as they were intended to be run with stock fuel pressure. Don't know whether this may have any impact? Quote
scottieboi94 Posted May 3, 2014 Author Posted May 3, 2014 My understanding is that P&P ECUs don't like FPRs as they were intended to be run with stock fuel pressure. Don't know whether this may have any impact? The only reason i would say is would have an impact is because it has ran fine for months Quote
TurboTobz Posted May 3, 2014 Posted May 3, 2014 Some fprs like fse are prone to losing pressure over time causing stoof like this Quote
brendonware Posted May 3, 2014 Posted May 3, 2014 Yeah, this is why I'm thinking Im having an issue, think my fpr is breaking, even though it's still giving the same pressure reading :/ Quote
scottieboi94 Posted May 20, 2014 Author Posted May 20, 2014 Ever since i have put new spark plugs in and re-routed my earth cables it's gone back to starting every time, and it starts almost instantly like it used to. So i haven't got a clue what the problem was lol It was raining the day it happened so there may have been some water somewhere that affected the ignition. Quote
brendonware Posted May 20, 2014 Posted May 20, 2014 what do you mean re-routed your earth cables? sorry im having the same problem Brendon Quote
scottieboi94 Posted May 20, 2014 Author Posted May 20, 2014 Well it was starting fine before the earth cables to be honest, but one of my earth cables snapped so i put a new end on it and put it at a different point on the car, i think it starts a bit quicker since ive done that tbh Quote
