hi all,
Decided to move away from the saxo's and 106's to something with a bit more power :)
more of an impulse buy really when i was browsing gumtree when i spotted this wee motor. it has 225k kilometers on the clock which is fairly high but the car seems in good condition given its age and miles. i believe the wheels are 16" kosei senaka racing wheels which are in dyer need of a refurb. front bumper has a nasty crack along the bottom with a botched repair that will need attention.
few pics from the add itself
5A152F31-8D39-4B09-BB74-11E27BAB7147_zps
91A10977-C7D4-4912-90A7-44FD475E5255_zps
0A1D68A8-5582-46B8-B460-BE4522A0BDF9_zps
7679814F-EF65-4576-B424-76AF7B18A665_zps
as you can see it has a wee mbc which has been pulled out, also a manky boost guage which is out as well.
bought the car knowing there was a severe knock coming from the engine so the big ends are away. whipped the sump off when i got it home the find the rods had loads of play on the crank so new engine time.
paint work was boging with a black film on it so got the tar remover out and the difference is shocking :o
3bee9b59-0c5a-4e12-9854-5e0408126131_zps
so i got cracking with the engine removal. picked up a gt engine from the owner of tgtt who ive met before so it will be good having a guru close by.
4A5E169E-4AB2-4EA2-9D77-F32AB1C22331_zps3921263A-B635-4E62-8DAC-8F85AFBEABB7_zps
got the block cleaned up and it got a lick of paint to freshen it up
BBB936E5-9071-4754-83B7-7DD2B603E14B_zps
then started swapping everything over from the knackered engine
CF379DE5-B7D6-4A9B-935A-BF26633201A6_zps
F001FE1B-BCF5-412D-BC86-985775D84EAE_zps
1DFF1373-67B5-45F9-9E36-D05810F4B099_zps
0F3FE54D-5C0F-4751-860A-CE3B92677CAE_zps
new crank and cam seals as i was imformed they were all weeping and it makes sense to change them when i have the chance
AFA85DA5-2DE9-42F0-89B7-1D417ACFE998_zps
freshly painted sump put on with some decent sump sealant
D57FE066-1C4C-4ED2-8741-AEE8F87A9CD1_zps
when rotating the engine up right again i heard a rattle in the cat so whipped it off to find this lol
E1898DE0-4963-4D33-95AC-8DB7668C38FB_zps
i had to use the old rocker cover as the gt one is slightly different as breather hoses are placed elsewhere
fired up nearly first try as the negative terminal for the battery has a bad connection which is now sorted. unfortunately my glanza inlet doesnt have the waterway as the gts do as you can see in one of the above pics (the wee square hole on the head) so im getting a hold of and inlet next week and then the car will be mechanically sorted.
pulled the carpet out to find rusty footwells and the boot is very untidy so got it all prepped and painted. boot needs another coat of 040 and clear coated and the inside of the car will be sorted. once that is done the only thing left is refurbing the alloys, repairing the front and rear bumper, side skirts need attention and the door hinges need replaced. given what i paid for the car, ill have a very decent car for less money than buying one in a similar condition.
thanks for reading so far. will keep the progress updated as i go
cheers
cheers for your reply lads
I got the manky floor sorted and also tidied up the boot floor/wheel well. sorry dont have any before pics but the foot wells were rusty and the sound deadening just chipped off in big chunks.
C3D9CEE4-BC75-4CA8-96E6-B6B5DD24D145_zps
994E65AE-46C1-49E7-A272-2678C43751FC_zps
didnt bother spraying under the rear bench as it in good nick, now that i think i should have done it while i was there lol
got some parts ordered from toyota wont be here til friday, and another exciting purchase is on its way too.
cheers for looking
